Results 1 to 10 of 15
Thread: 4.6 noise. Video inside
    Niva Guest
    Hey guys,
    I have a 1998 HSE (p38a) with a rebuilt engine about 70,000km ago
    Recently I noticed a very diesely sounding noise just above idle when cold. Only happens at cold and only betwen idle and say 1800rpm
    Madr a video so thought id chuck it up and get some expert opinions cheers!
    James
    [ame]https://youtu.be/OFQBHBvlyww[/ame]
    Aug 2010
    Pakenham
    Only speculating here.
    Possibly incorrect grade of fuel.
    Exhaust manifold gasket. As it warms up, the gaskets expands, but when cold it may leak a bit along with some faint un-muffled noise. That s what it sounds like.
    May 2003
    On The Road
    could be a couple of cylinders missing,,,
    Jan 2016
    Netherlands
    I don't want to hijack this thread but I believe I have a similar issue with my engine. If I heard it correctly.
    I added a video which has the ticking sound more pronounced. The engine only does this when cold and I am not missing any coolant etc. so it does not seem to be the dreaded cylinder liner problem. At first I thought maybe a valve job was needed but I would not expect that to go away when the engine is warm.
    A gasket seems a legit option but I can not feel any air leeking and the tick is on the loud side for just escaping air. Any more suggestions?
    Attached Files Attached Files
    Feb 2010
    Townsville, QLD
    Sounds like a broken rocker to me...
    Apr 2010
    Lower Hunter Valley NSW
    After listening to that, yep have to agree with Keithy. Definitely something not right under that rocker cover.
    Sent from my SM-N9005 using AULRO mobile app
    May 2003
    On The Road
    If the rocker cover had to come off,,,
    whatever else you find wrong--
    I'd be retensioning the head bolts,,
    why?
    because you can.
    Crafers West South Australia
    Cracked exhaust manifolds tend to quieten down after they get hot and the cracks close up.
    Jan 2016
    Netherlands
    Thanks for the tips.
    Since my wheel bearing is shot and the car has not moved in a while I can see quite a bit of oil that has leaked passed all sort's of gaskets so I think it is just about time to give the V8 a long deserved overhaul soon. Not sure if I am going to invest a a complete rebuild engine, do the work myself as a hobbyist (with all the risk involved) or just do the needed.
    Anyone have any thoughts on that?
    Cheers!
    May 2003
    On The Road
    Our RV8 is not a technical marvel
    Lots of info on (here) how to replace gaskets properly.
