Yes it can be disabled
Originally Posted by
PLR
G`day ,
as i understand .
HSE and Vogue with memory seats also have memory steering column .
SE won`t normally have memory seats .
My question is are the SE columns only manual adjust or will they still move with the key ?
Can the memory function be disabled or is it seen as an important function ?
The first part is accurate as mentioned previously. That is, the SE is adjusted manually, and the HSE and Vogue remember the settings of the steering column, seat and mirrors according to the key inserted. Moving into place as the key is used, and out of the way when removed.
Yes, this feature can be disabled. You need something like a VCS, Autologic, IIDTool or BBS system to do so. Other devices may have the ability but I am unaware of that functionality on them. Certainly my HawkEye doesn't have the ability, but then unlike most of the above its not VIN locked.
A friend has this function disabled on his 03MY HSE to avoid excessive use of the column adjustment motors.
Hope that helps some.
Iain
Iain
VK3BIT
03MY Range Rover HSE Td6
Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
LROCV DTU member
