Results 1 to 10 of 37
Thread: 18" Tyres on Sand
    Aug 2014
    North Stradbroke Island
    18" Tyres on Sand
    Need some new tyres for my D2a which unfortunatly has 255/55/R18's on it. I live at the beach and drive on sand a bit. I haven't found these tyres that great in the sand, I also worry that I'll roll them off the rim. Is it possible to go to 255/60/R18, might give me some more sidewall (25mm more I think). Might rub maybe not sure. Any opinions on this as would be a lot better in the sand?
    Oct 2007
    Brisbane West
    Mate If you look around a set of 5 16in LR rims can be had for $100-$150. LR factory alloys hold the bead like no other.
    Aug 2014
    I've had D2's with 16's before they are great. I think I have the Hurricane 18" wheels which are really nice looking they would have the same bead wouldn't they? All of the D3 and D4's have 18" or 19" wheels how do they go offroad I wonder, they don't maybe?
    Brisbane, Queensland
    I would go with 16s on a D2. However if you really like the 18s it shouldn't be a problem with 255/60 or even 265/60 tyres. 265/60s are smaller in diameter than 235/85/16s and some people use that size on a D2. The 265/60/18 is more readily available these are often used on Prados etc.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Aug 2014
    I've read a thread about Tyre Sizes in Technical Chatter, Slunnie posted this helpful link:Clifton Scientific Text Services, the Netherlands
    where they say that 30.5" is the biggest size without adapting the rear wheel carrier, not too worried about that, I suppose its also going to throw out the speedo, I'll use a gps and get used to new speeds. So I guess that either the 30.5" 265/60R18 or 31.6" 265/65R18 is the go, I'll see what I can find thanks.
    sheerluck Guest
    Quote Originally Posted by Islandnomad View Post
    .......All of the D3 and D4's have 18" or 19" wheels how do they go offroad I wonder, they don't maybe?
    Yep D3s and D4's never go offroad, and all of the pictures in the D3/D4/RRS forum have been faked.
    Aug 2014
    Haha just a throw away line about what do they do, as they all seem to come with 18" 19" and 20" wheels and low side wall road tyres as standard which aren't that capable offroad? They all have the same problem, seems they go the 30.5"-31.6" route too!
    sheerluck Guest
    They do come with small sidewalls as standard. But the D3/D4 are a very different beast to a D2. The traction control and Terrain Response functions are very, very good. But that's a bit of a side track from your original post.
    Aug 2014
    Just wondering what the D3/4/RRS people do to make their vehicles more offroad friendly, than persisting with road tyres? Capable machines but need decent rubber offroad (probably the most important thing).
    In the back of my mind my 2004 HSE does have ACE, apparently 18" wheels are a lot better for ACE than 16"??? Read that somewhere?
    sheerluck Guest
    Most D3/D4 drivers will put a set of decent AT type tyre on, compared to the standard HT tyres, and some will go up a size or two, to 265/60-18 or 285/60-18 (as in my case).
    Have a browse through the D3/D4/RRS forum to get some ideas.
