Thread: Hub socket size
    Oct 2014
    Northern NSW.Australia
    Hub socket size
    Just checking before ordering.
    Is the series 3, ( 10 spline ) Hub socket size 52mm.
    Local repco said they would look after me, but need to order that size in.
    whitehillbilly
    As they say, search is your friend.
    See Hub Nut Spanner
    You don't need a real socket. A tube spanner will do, e.g., Land Rover HUB NUT Spanner HUB NUT Tool | eBay
    I was about to write they are much cheaper but I just had a look on eBay and I'm not so sure now!
    Oct 2014
    Thanks Ron,
    $20 to $30, tube spanner, will end up cheaper at my local repco, 1/2 inch drive socket.
    Its a surprise the cost, when someone you know, looks after you !!!!
    52mm then.
    whitehillbilly
    Narre Warren South
    52mm will do, if you're ordering parts from the UK they are quite cheap.
    606435 | Hub Nut Spanner - for use with bar - Paddock Spares
    I think the nut is 1 1/4" Whitworth (1 3/8" BSF). A discussion on the forum years ago mentioned a box spanner for an immersion heater in a hot water tank being a similar size (may have been NZ rather than Australia though).
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Oct 2014
    Hi Gromit.
    4 quid socket, 10 quid postage.
    $28 delivered. Ebay prices.
    Thanks for the replies.
    whitehillbilly
