Results 1 to 9 of 9
Thread: Brake shields necessary?
    Feb 2009
    My mechanic assures me the front right rotor shield is where it should be, but every time we even look at a gravel road it picks up stones and starts squealing. If I'm lucky I can flex it enough to free up whatever's in there, but if not we have to put up with the squealing until it falls out.
    Before I rip the thing off in a rage, it would seem they exist for a reason but I'm not sure what it is? What's the worst that can happen without them on? The inside of the rotor doesn't wear as quickly without stones permanently wedged against it?
    Thanks in advance, L319 and L320 enthusiasts!
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    You must be unlucky!
    They keep water spray off when raining so you don't get fade, and they keep most abrasives from ripping the inner pad apart..
    Feb 2009
    Some would say!
    I wonder then if they can be modded. I know there's aftermarket ones for Defenders but if I'm the only one with this problem it might be up to me...
    Sent from my SM-G900I using AULRO mobile app
    Feb 2009
    Mt Barker, SA
    Quote Originally Posted by Stuart02 View Post
    Hi Stuart, this has happenned to me a few times with both the RRS and the Puma. Each time it has been fixed by stopping and reversing a few metres - the stone dislodges and drops out. I may have just been lucky though. Glad to see you still posting in the D3/4 forum as this is a shared issue like so much of the shared platform RRS and D3.
    Feb 2009
    Quote Originally Posted by Marty110 View Post
    Thanks Marty, that has worked on occasion.
    The weird thing is that it's always the right front. It's beyond me!
    Feb 2009
    Mt Barker, SA
    has the right one been damaged in some way? maybe bent a bit closer so less clearance? Wouldnt take much so could be hard to eyeball........ this was the case with my Puma so a little gentle bending solved the problem
    Feb 2009
    It must be something like that, thanks
    LRD414's Avatar
    Oct 2014
    .... if I'm the only one with this problem it might be up to me...
    Stuart, I've had this happen three times in about 7000km of dirt road/track driving.
    Each time it has been cleared after hitting ~80km/h once back on bitumen.
    I haven't tried driving briefly in reverse but can see that working too.
    PS ... I'll still talk to you even though Tribal Council has spoken.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Feb 2009
    Quote Originally Posted by LRD414 View Post
    Maybe 180 kph will do the trick?
