Results 1 to 4 of 4
Thread: Will these alloys fit a track trailer?
    Gold Coast, QLD
    Is anyone able to tell me if there are any known issues fitting these alloys off my RRC onto a standard military track trailer?
    I have to pick one up this month and it needs tyres, so was going to use these to do the job until I sort out something more permanent.
    I understand the PCD is the same, but an not sure what offset is required to clear any other components (shock absorbers / elec brakes / hubs etc).
    The remaining specs to disclose are the rims size is 15x7 (not sure of exact offset someone may know the specs of the rims?)
    Tyres are 31x10.5s
    Any info much appreciated!
    Grimace
    I rule!!!
    2.4" of Pure FURY!!!
    Gold Coast, QLD
    I guess there is only one way to find out
    I rule!!!
    Australia
    Obviously you need the alloy wheel nuts. I don't recall there being any issue with width or clearance. Stud length is good and brakes are a simple hydraulic drum brake. Electric brakes weren't a standard fit to my knowledge.
    Avoca Beach
    If the PCD is the same I know you can fit RRC mags.
    HOWEVER ALKO studs are imperial and RRC nuts are metric. I don't know whether you can get nuts to fit your old mags, so you better research that.
    The other issue may be if the trailer has 10 inch ALKO drum brakes, then the RRC mags will fit over the end of the bearing retainer but your mags may not.
    Regards Philip A
