Originally Posted by
oyamum
My question is what are some things I should look out for when I pick her up?
Any common problems the classics have? I'll be driving it back to melb so don't want any common problems to catch me out...
Thanks in advance
Answer to 1: Everything.
Answer to 2: What common problems DON'T they have....
I say this to everyone, (especially to first-time MB buyers, who seem to be ignorant of the potential pitfalls of purchasing a 20+ year old car) regardless of their ownership history or experience...
Unless you can do a properly thorough pre purchase inspection yourself (and remain 100% objective) on the vehicle in question (any vehicle that is, regardless of make), then you simply do not know what the actual condition of the vehicle is - and you should get someone to do an inspection for you if you are unable to view the vehicle (and I always strongly suggest you don't buy something sight unseen).
Use a widely respected & recognized independent specialist LR workshop. Do not take it to the local garage.
Their PPI report should give you a detailed list of all serviceable items, as well as those requiring immediate / urgent attention, suspect serviceable items which function but requiring more observation and items which are sound, but due for replacement according to service schedule intervals
That includes listing of all the appropriate sounds/noises are present/not present, fluids, seals, brakes, drivetrain, electrical test results, rust the lot.
Without that information, you cannot make any educated analysis of possible issues. Further to that, to make blind assumptions based on a list of commonly known issues means bugger all as well. Noone can predict what could or will or will not happen when they haven't seen a vehicle.
Seriously, that's a pretty broad reaching question you are asking. If you've seen the vehicle, and you still have this question, then you need to have someone else look over it and do the PPI.
Otherwise, it should be happy motoring, because having done your homework, you should be good to drive.
So long as you have a full roll of tools, coolant, gear oil, ATF, brake fluid, water, gaffa tape, #8 fencing wire, pliers, jumper leads, and a list of phone numbers for flatbed towtrucks between your pickup point and destination.
Don't laugh. I'm serious. Prepare for the worst, Hope for the best. If you prepare, then chances are nothing will go wrong. If you don't, chances are everything that can go wrong, probably will.
Enjoy the drive. Head over the snow, forget the highway. It's a much nicer drive back in through the east.
Reason: fixed typos
Roads?.. Where we're going, we don't need roads...
MY92 RRC 3.9 Ardennes Green
MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
MY99 D2 V8 Kinversand
