Results 1 to 10 of 29
Thread: Low power in a td5 (again)
    May 2016
    Alexandra Hills
    Just a quick question I have a 2001 td5 and its gutless to say the least. Only had the car two weeks but I am sure something is wrong. After using the search button have been through a number of check like disconnecting the MAF etc no difference. Have replaced the injector loom harness and flushed the wires. Also given it a full service. I have noticed the FPR is leaking ? I also started the bleed function by pressing accelerate pedal 5 times. Only problem is it just kept going. Didn't seem to want stop. Just wanting to know if anyone has had similar problems with lack of power etc
    Sep 2009
    Waste gate stuck perhaps? That is, no turbo boost? Check to see if it is moving.
    May 2016
    Alexandra Hills
    Waste gate moves but is tight. No splits in hoses new silicon i/c hoses fitted. Will get codes cleared and re checked just wondering if its common for FPR to cause low power ?
    Jul 2014
    west of Transylvania
    Check fuse F2 in engine bay to rule it out, though a certain answer would be given by a tester to see how the management works, bad AAP, MAP, IAT or FT readings can make it powerless, so does a faulty wastegate modulator, some late 2001 modells were fitted with CAT so if your's have one this can be an issue too if it's clogged.... hard to diagnose it without a tester
    Sep 2009
    My original suggestion was going to be that the modulator may be faulty, but doesn't this normally cause over boost? Has it ever caused the wastegate to open prematurely if faulty?
    Jul 2014
    Quote Originally Posted by bsperka View Post
    You are right, in most cases it causes overboost cos it doesnt open at all then there's no pressure on the wategate actuator but i've seen cases when it was stuck opened then the wastegate will open sooner cos it gets the full boost from the beginning like when you bypass the modulator... the management of the D2 is made to work with that modulator as to bleed pressure into the intake at low throttle so an opened one will make it sluggish especially at low revs... also if the problem is with the modulator's coil it can blow fuse F2 and this is the feed for the MAF too
    NSW SW Slopes
    If the previous owner only idled around then the waste-gate may be very stiff to move and is stuck wide open from the last time it was given a boot-full. Disconnect the rod and check that it moves freely.
    Free Again Thanks Dan
    Turbo hose
    May 2016
    Alexandra Hills
    I have cHecked the fuse all good. For anyone who knows Brisbane the gateway bridge has been my test track on the way home from work. Even with a run up and sitting on 80 the car will slow to 60 I worked it hard to test and revs went up to 3500 to 3700 still doing 60. It will rev just not making power.
    cairns
    Quote Originally Posted by steako View Post
    Sounds like it must be an auto?
    And that may be where the problem is.
    Or the clutch is slipping badly.
    Paul.
    77 series3 (sold)
    95 300Tdi Ute (sold)
    2003 XTREME Td5
    I thought I was wrong once, but I was mistaken.
