Results 1 to 10 of 20
Thread: Best low beam headlight? Crystal vs LED vs?
    May 2014
    A clash with a kangaroo has left one of my original sealed beams illuminating even worse than it did before (as unbelievable as that seems) so I'm in the market for a new set. My main concern is the quality/brightness/spread of the low beam's as I've got extra driving lights to take care of the high-beams, as well as the price (student budget).
    So questions.
    1. Would I need to update the wiring if I opt for LED? I know Dervish's fix and would use that if I opted for Halogen.
    2. Has anyone used a knock-off LED set off Ebay? What did you think?
    3. Ignoring any other changes (wattage or wiring) are the Wipac crystals any better than the originals (I think they're the same as the SVX lights??)?
    4. Has anyone been unhappy with LED replacements? Particularly Truck-Lite I'm curious about as JWS is beyond my price range
    5. Would anyone recommend HID? I have zero experience with them except that I hate all the idiots with their bodgy conversion dazzle jobs.
    6. Where can I get Cibie Z-beams? Have only ever heard fantastic reviews but seems they're out of production?
    Niels
    Snowy - 1998 300tdi Defender 110
    Past:
    The Toad - 1992 200Tdi Defender 110
    Dec 2008
    Victoria
    Sorry mate I can't help you but watching with great interest.
    As an aside I did inquire recently from my Landy independent work shop about replacing my original Rangie Classic factory headlights - H4 7 Inch - with new ones the same but not LR factory brand. The quoted price of $800.00 a pair plus fitting turned me away from that idea very smartly.
    Yass NSW
    We put a set of Narva clear polycarbonate 7" halogen lamps into SWMBO's wrangler after a similar incident. They are a significant improvement on the factory glass halogen units and don't get stone chips either. About $80 on special at Repco...
    Regards,
    Tote
    Quote Originally Posted by Plutei View Post
    1. Would I need to update the wiring if I opt for LED? ...
    Hi Plutei,
    I replaced my IPF QH headlights with the Truck-Lite LED units.
    The Trucklite I got have a universal / military spread, that means they spread out and low on both sides on low beam and can be used in RHD or LHD jurisdictions. I'm not sure if the latest version is RHD biased.
    I have probably aimed them a little low, as I wasn't sure whether they'd dazzle like HIDs. The light is good (High Beam is better) and even on high beam it doesn't seem to dazzle other drivers. So I better adjust them up a little.
    The benefit of the HIDs is that the light switch won't get hot carrying a large current and eventually fail, which is common for factory Defenders. The Truck-Lites were not a disappointment after the IPFs with upgraded wiring, so I don't think they'll be a disappointment after factory lights.
    A short (19") light bar complements the High Beam nicely, and there really isn't need for much more up front lighting at the speed the Defender travels at; so less lights over your radiator.
    JDNSW's Avatar
    The biggest improvement you can make to low beam, regardless of what type of light, is to fit relays so the lights are operating on full voltage. For low beam, it is unlikely that fitting any lights above the legal light output is worth the problem of fitting headlight washers and wipers and levelling as is required (this applies to all HID lamps and probably many other lights as well).
    As you comment, the better spread of light is the important bit. It is hard to get clear information on this aspect of any replacement lights, but I was recommended and got some years ago Cibie halogens, which were an improvement on the originals, but I like the look of 'crystal' lights, although there is no inherent reason for their performing better. And I really would like to be able to justify LED lights, but I at present I don't think they are worth the premium cost at present.
    Mar 2016
    Ballarat
    Hi, I've had the Trucklite LED's in my 90 and had them taken out when I traded up to my 2016 110. I was really very happy with them and loved the improvement. I thought they had been aimed a bit low at first but after a while considered they were spot on. I'll have them installed into my 110 when I have a couple of jobs for Les Richmond to do for me
    May 2014
    Thanks all. Where and for how much did you source the trucklites? I think I'll go with either the narva free forms or the trucklites but it comes down to the price I can get the LEDs for.
    Niels
    Past:
    Dec 2012
    Snowy Mountains
    The standard glass H4 semi sealed headlamps are quite good....yes I believe so, after fitting a set of Philips Xtreme globes and relay.
    HID in H4 is very poor as the globe focus is poor on the reflector.
    Mar 2016
    Ballarat
    Hi Plutei, I bought the pair of them from Westar Truck Centre in Derrimut Victoria for $751 (pair) which included GST
    May 2014
    Ouch! I've heard of them going for as little as $450 but I think there must have been something special going on there as I definitely can't find them for that little.
    But I have found the Narvas for $85 at Supercheap.
    Niels
    Past:
