Thread: Stupid plastic clips on grill
    Ean Austral Guest
    Gday All,
    Has anyone come up with new system to replace those stupid U shaped plastic clips that hold the top of the front grill in.
    Whomever designed that shocker idea needs the rough end of a pineapple shoved fair up their clacker
    Cheers Ean
    Williams West Aust
    Tried a bit of fence wire Ean
    ENJOY
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Ean Austral Guest
    ENJOY
    Andrew
    Was thinking along the lines of the metal saddle clamps manipulated with some pliers.
    Cheers Ean
    Ean Austral Guest
    Well I tried a few different ideas but didn't want to drill into the plastic grill , so some trusty cable ties actually work well. You can feed them behind the grill and back thru the next hole where the next clip sits , pull them tight and the grill don't move.
    1 long cable tie on each side and all done, just be careful as there are some wire's tucked up behind the grill so dont capture them with the cable tie as they may wear thru over time.
    Cheers Ean
    Williams West Aust
    Make sure you buy good cable ties.Cheap ones have no UV protection and go brittle pretty quickly
    Andrew
