Thanks... my VIN falls in there might mention it next time I'm at the dealers.
Hi Folks,
I was looking at the sister site and found mention that there is a recall in UK for action P080.
The title in TOPIX is "P080 - Crankshaft Position Sensor Signal Issue". The chassis ranges Land Rover suggest, if renewing the sensor it's advisable to renew the pick up ring.
D4 VIN range in scope: AA510178-CA652214
I wonder if this will ever appear here? https://www.recalls.gov.au/content/i.../itemId/952880
Mark
2003 D2a TD5...gone...
2000 D2 V8...gone...
https://bymark.photography
Now listed on AU recall.
Jaguar Land Rover Australia
campaign number: P080
VIN Range (Selected vehicles within VIN ranges):
Discovery SALLAAAG5CA626785 to SALLAAAM6DA653082 (976 vehicles)
Range Rover Sport SALLSAAG6CA752903 to SALLSAAF4DA787400 (1,081 vehicles)
Range Rover SALGA2KE6EA000013 to SALGA2HF4DA124233 (62 vehicles)
Ive had a couple of occasions where my engine would not start.
Vehicle only months old.
The I pushed start button the dash lights came on, then silence.
Sweating bullets, I pushed start button without foot on brake, everything powered up, then I pushed again with foot on brake.
Bingo.
Its only done it twice.
I will mention to dealer at service time.
Cheers Vin
2025 D350 Defender 110
Mine has a N in the vin,effected vehicles finished at M
Prefer not to have a recall.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
According to the UK site, the worst scenario is you're driving down the road and the engine dies - then you lose power steering and brakes - and head off into a ditch. It seems to have already happened over there.
OK - an update from the first post, which I am no longer able to edit.
There are two parts to this issue - clarified from Topix:
LTB00680: VIN AA510178-*CA652214
P080: VIN 626758 - 653082 (years 2012-2013)
So while the problem is known to affect a large number of vehicles (per VIN range in services bulletin), they are only recalling only a small number. Let's hope they got it right.
 Fossicker
						Fossicker
						just received a recall notice from LRA to advise me that the Crankshaft position sensor could be faulty and they wish to replace it
Love the clause
"Engine cutout with minimal warning could potentially cause a crash"
If fitted with air suspension system will reduce vehicle to lowest ride height position
From what they tell me it certainly throws some faults into the system and explains a few certain things that have happened to our vehicle (Fail to proceed) wouldn't start
refers to D4 2012-2013MY, Range Rover 2013-2014MY, RRS 2012-2013MY
