Hi
Take the blown fuse and solder a wire to each terminal so you have a tail or park light bulb now acting as the fusible link.
Use this in the fuse spot that keeps blowing, when you switch any light on in that circuit the inserted bulb (and the vehicle lamps in that circuit) with dully glow. (series circuit instead of a parallel circuit)
Wriggle wiring looms around and see if you can get the inserted lamp to light up with the troublesome vehicle lamps turned on.
If you can get it to light up to full brightness, you are moving wires that are part of your problem and have now caused the short circuit. A bit of futzing about should locate the offending problem spot.
