Thread: hope this helps someone
    May 2014
    Ok had a problem with the td5 low on boost only 8psi no faults stored a slight rattle at idle and a vibration at 2200 rpm
    Well found the cat rattling stopped it by putting foot on it
    Ordered decat and centre muffler removal pipes
    Today went to sort out low boost fault but thought would fit the exhaust first
    Test drove and wow went to overboost spinning its wheels off the mark never seen it go so well
    Readjusted boost and test drove again it's awesome well the blocked cat caused all our troubles and engine seems to breath better so may cut down on amount of oil entering intercooler and poor fuel consumption only getting 13.8/100 so will be watching to see how much this improves
    1960 series 2 143001010
    1976 series 3 91331709c
    06 discovery v6
    2014 discovery tdv6
    2010 cub supamatic drover
    Oct 2010
    Caloundra
    Who'd you get the kit from?
    May 2010
    brighton, brisbane
    Quote Originally Posted by Dgd69 View Post
    Thanks for that, at the risk of being pedantic [ and being wrong], I assume by cat you mean catalytic converter. AFAIK, only the V8 has catalytic converters. One in each front pipe. The V8 system has 2 cats, one in each front pipe, leading to an intermediate pipe/ silencer[ muffler] assembly, then to a tail pipe /silencer assembly.
    The TD5, on the other hand, has a front pipe assy. leading to an intermediate/silencer assy., then on to a tail pipe / silencer assy..Each silencer is constructed of stainless steel sheet, with baffle tubes, and fitted with stainless steel fibre packed around the baffle tubes. [ this description is from RAVE. ] Replacing the intermediate /silencer assembly with a straight thru pipe is said to improve performance, as for the tail pipe silencer, perhaps yours had collapsed partially. You have improved your performance, and are happy, that is the main thing.
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by bob10 View Post
    I, for one, would love a clarification on this one. I have read that Cats were post 2004, that all TD5 Discos had them, that NO Diesel Discos did. Seems that not many folk actually know, but all report an improvement in performance when the thing is removed!
    Now, I know from the truck world that diesel cats exist, but did the TD5 actually have one, in this market at least?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Mar 2009
    Port Stephens N.S.W
    Yep. Mine has (had) one. 02/2004 build. The facelift model with the later Eu3 spec Td5.
    Earlier Td5's (square headlight models) didn't get a CAT (in oz) afaik.
    Mine goes better since I got rid of the moggy
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Cambewarra, NSW
    All TD5s from 2002 onwards originally had the Cat fitted (EU3 spec engines)
    May 2014
    Yep mine is a 12/2003 definitely had a cat and it its whole new car with it removed
    06 discovery v6
    2014 discovery tdv6
    May 2010
    brighton, brisbane
    We learn something new each day.Mine is a 1999 model, definitely no cat. 396,000 KM's, still going strong. [ now I've done it] Happy motoring.
    Feb 2011
    Hobart, Tasmania, Australia
    Later model D2's definitely have cats fitted. Mine is a D2a built Sep 02 and had one.
    Bairnsdale enjoying the rural view no rooftops to see here
    I have wrecked several pre 2002 cars which had them
    Sent from my SM-G900I using AULRO mobile app
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
