Thread: Maybe a dumb quesstion, different rims on the same axle?
    May 2015
    Williamstown, Victoria
    I know that different tyres on the same axle is not recommended. How about the same tyres on different rims on the same axle?
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    Adelaide - Torrens Park
    If the rims are the same size and offset it won't matter.
    May 2015
    Quote Originally Posted by BigJon View Post
    Offset? how is that measured?
    LROCV #1410
    Mar 2009
    Port Stephens N.S.W
    Shouldn't matter. The rim masses will differ, and the widths are likely to differ, even different offsets are ok (as long as they don't rub), but the rolling circumference will be the same, and that's what matters.
    Sent by iPhone using two tin cans and Forum Runner
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Jul 2014
    west of Transylvania
    +1 for that ^^^, rolling circumference/diameter MUST be the same or the TC might not let you drive it much
