Results 1 to 10 of 18
Thread: is there a priest in the group ?
    May 2016
    nowra
    Today ,,,oh god not again !
    took the wife for a drive ,,
    The alarm goes off and the gearbox goes into limp home mode ?
    So ,,, any ideas ,,,
    I clear the fault and drive away happy ,,,
    no dramas
    start stop lock un lock ,,,
    No dramas ,,, so then i thought ,,, try setting off the alarm
    so i lock the car with the window open
    after 10 minuets ,,, i stick a broom thru the window
    The alarm goes off and trans in limp mode ??
    clear the code all good ??????
    car possessed?
    99.87 MB
    Exorcism?
    I think the process is detailed in the workshop manual.
    Slunnie
    May 2016
    nowra
    Yep ,,,,,
    Exorcism?
    a big one ,,, like heads spinning ect ect
    A little girl saying
    "THERE BACK"
    HELP
    Quote Originally Posted by rob tilbury View Post
    Maybe not a priest but there is a Reverend.
    May 2015
    Williamstown, Victoria
    Imaginary Friend
    Getting hold of a god botherer to talk exercise (sic) an non existant entity will not help. Consult the learned brethren here, will. Read the good book, RAVE Discovery 2. The blessed Sierrafrey may offer some advice.
    Build date 11th Oct 2003
    LROCV #1410
    May 2016
    nowra
    true that ,, But
    Never heard of a auto trans going limp mode when the alarm is activated ??
    anyone else ?
    May 2010
    melbourne
    Doesn't a low battery cause possible m&s faults? Could it be the alarm going off is draining battery a bit to much?
    Oct 2003
    Montrose, Vic.
    low battery can cause lots of odd things.... certainly would be wise to check.
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Aug 2010
    Adelaide
    Rob
    If the M&S lights were flashing try this: Press the Fob lock button, pause, then press it again, so double locked. (walk around the vehicle 3 times) Gives the computer time to think !!!! then unlock and start it. Worked on ours more than once when it had that problem. No idea what was wrong, except it appeared to be a security issue.
    Harry
    May 2016
    nowra
    Talking Thanks Harry
    I have load tested the battery and seems fine .
    2 things i can think that may do this ,, as you sat a security issue glitch in the programming ?
    OR
    my Wife
    As it breaks down every time she gets in the car ,,, she now phones a friend before we set off to make sure some one will be around
    Its getting embarrassing
