                                                11th July 2016, 03:01 PM
			TD5 turbo
					hi
 well looks like my waste gate? on the turbo is seized and i need to either replace or rebuild the turbo
 mechanic is quoting me around 2 k to replace
 no idea on a rebuild cost
 have had a look for a replacement myself for around 1200
 i guess im looking for advice on what i should do next?
 the car is a 2000 110 with around 170on the clock
                                                11th July 2016, 03:23 PM
					what are the symptoms??
 If it is a seized wastegate spindle:
 *Take it for a drive and get it warm.
 *unbolt and remove heat shield, the one bolt down the side of the heat shield is awkward but not impossible.
 *unbolt the diaphragm unit, remove the circlip (just so its all out the way).
 *Now you can clearly see and get to the wastegate spindle, spray a bit of lanolin spray round the shaft and lightly tap tap the spindle in each direction to try and free it up, the money is on that sooner or later it will start to free up, keep working it until its rattly loose, spray a bit more lanolin onto the shaft.
 *re-assemble.
 I do this on customers TD5 engines all the time..... you know, rather than have them spend $2500 on a new turbo...
 *While you are in that area of the turbo, remove the plastic intake that goes into the turbo so you can clearly see the turbo intake vanes, see if it spins freely with your fingers, if it does, all ok, also visually look at the blades for damage and wear.
 Daz
Daz
                                                12th July 2016, 06:59 AM
					symtoms are
 at any speed if i plant the foot it sort of starts to choke and blow a lot of black smoke
 thanks for the replay but im no mechanic and have it at a place on the coast being repaired
 thinking i might just go new as i plan on keeping the car for a few years yet and dont want to get stuck somewhere because i screwed it up
 any idea what the part number is or a good place to purchase the correct part from?
                                                12th July 2016, 08:16 AM
                                                #4
					This is a typical symptom of a delaminating turbo hose.
 As per DazzTD5 post - Shame to replace a turbo for a stuck wastegate
                                                14th July 2016, 01:43 PM
                                                #5
					I'm definitely not an expert, but the previous owner of my TD5 has warned me about a sticking turbo waste gate and that I should lube it ever 2-3 weeks.
 Searching on forums shows its a common problem that can be freed up.
 Worth looking into before shelling out a couple of grand.
 Land Rover Owner • View topic - TD5 sticky turbo wastegate?
 There are also some youtube videos of people freeing them if you search waste gate stuck
                                                29th July 2016, 10:23 AM
                                                #6
					ok
 so the turbo needs a rebuild and thats getting done, but i need to get the three gaskets
 any idea of a part numbers ?
                                                29th July 2016, 10:31 AM
                                                #7
					I have a good working order second hand turbo that I've just pulled off my Discovery to fit a VNT if you are interested.
                                                29th July 2016, 10:34 AM
                                                #8
					i might have thought about it a few days ago
 but its in the shop as we speak
 thanks
                                                29th July 2016, 10:53 AM
                                                #9
					ok the two gaskets i need are
 turbo to maifold
 turbo exhaust outlet
 any ideas where i can purchase?
                                                29th July 2016, 11:04 AM
                                                #10
					I thought it was in at a workshop getting repaired?
 If so...
 If its a Land Rover specialist, then i'd thought they would have a box of the metal gaskets.
 If not, then any Land Rover parts seller would have them, Rovacraft as one example.
 The big one turbo to exhaust, ESR 3737 widely used on not just TD5.
 Small one, ERR6768 manifold to turbo.
 turbo oil drain PNT100030
 Daz
Daz
