G`day ,
a good beginning point may be to have a look at the starter relay in the fuse box .
edit
More than likely the problem won`t be with the starter itself .
I don`t know if you can easily but removing the ( lucar ) single spade type connected wire on the starter solenoid itself , will help rule the starter out , the wire is what tells the solenoid when to work or when the key is turned it actuates the starter .
