Thread: GearBox Filler Bolt
    Jul 2016
    Australia
    GearBox Filler Bolt
    With the manaul gearbox filler plug as its an T55 bolt, can it be replaced with an hex bolt or something else?
    Feb 2011
    Hobart, Tasmania, Australia
    Can I ask why?
    The tool fitting on the head type is somewhat irrelevant - the thread type is far more important as to whether it can fit or not. Make sure it's both the same thread and I'd be careful not to go any longer without first checking clearance (I think that there's plenty of room though if I remember right).
    Only concern about the head is it needs to seal with the washer. Perhaps an internal hex (allen key) type head would be a suitable replacement rather than an external hex (socket/spanner).
    Jul 2016
    Australia
    I want to replace it as the previous owner has started to stop the torx fitting on it and I don't want to to get any worse and not be able to take off the bolt
    May 2015
    Williamstown, Victoria
    Quote Originally Posted by Yakuza View Post
    Why not just get a new T55 bolt? or a second hand one.
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    Jul 2016
    Australia
    I will try to get an second hand one then
    Crafers West South Australia
    If it was mine I'd just find a nice chunky hex nut and weld it to the filler plug so an ordinary ring spanner could turn it (space permitting).
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    I used a galvanised plumbing tap stop plug on mine, avail at bunnnings and the like, the ones with the square raised end, it worked, I was a lot easier than fiddling with torx bits.
