The correct kit for 3.9 to 4.6 engines is 157-4301
HOWEVER - you need to research further because I believe (but cannot confirm) that the kit you have will also work.
The kit you have was originally made for the original Buick V8 and goes across to the earlier Rover 3.5 V8s with their 14 bolt heads.
The 3.9s to 4.6s only have 10 bolt heads so the 157 - 4301 kit only has 20 bolts. The 124 - 4003 kit has 28 bolts which should (confirmation needed) be ok and you will have eight spare.
I would not torque the nuts to the ARP recommended torque as you run the risk of pulling the stud out of the block (plenty on google about this). The brains trust on here and elsewhere recommend about 70 ft Ibs.
There should be someone to either confirm or amend.
