Thread: Idle stepper motor IACV adjustment
    Feb 2013
    Gosford, NSW, Australia
    Question Idle stepper motor IACV adjustment
    Hi
    In another thread Benji wrote
    "The idle speed on petrol is done by first matching the voltage on the tps, then setting up the idle so that at 15 steps on the idle steper motor is around 750rpm. This needs to be done via diagnostics.
    I'm pretty sure you can alter the fuel correction by diagnostics too - I've never done it though."
    I replaced my stepper recently and I am having issues getting a stable idle.
    Does anyone know how do this procedure using a nanocom?
    Steve
    Jan 2012
    Bendigo
    https://www.google.com.au/url'sa=t&s...qvBYxEaR7GkwVQ
    Sent from my SM-G900I using AULRO mobile app
    Feb 2013
    Thanks mate, I found that as well as the nanocom GEMS doc has a basic procedure.
    It seems too simple for a P38
    Feb 2013
    I changed the setting to 15 using the nanocom and after a bit of driving it had set itself to 30 and I saw it as high as 38
    The Morgan document lays out the procedure perfectly.
    I read about the bleed air bypass screw getting clogged with carbon and I think mine is, i took the cap out and I can't see an allen key socket just back hard deposits by the look of it
    I'll have another look on the weekend, but I think cleaning and adjusting that screw should solve my problem.
    Thanks again benji
    Steve
    Feb 2013
    Turns out what looked like a build up of crud was a little black rubber stopper !
    So I tweaked the allen key setting and am now running at around 20 steps and my idle problem is fixed
