Results 1 to 10 of 11
Thread: Done option B now i need.......
    Afternoon brains trust.
    So ive finally done Option B. Much easier than i thought. Took about an hour, would be much quicker next time. I got my group buy nanocom so faults reset and im away. Went to the snow on Sunday kept trying to find ice and slippery bits just to hear that reassuring grind.
    Now i need to do the mod so that when i engage my cdl, I dont get the amigo's back. Ive looked at the post several times but i cant find it. Anyone with a clear idea where its hiding? I'd love to read the posts and do the mod.
    Thanks in advance.
    May 2016
    nowra
    You sir are a genius. I have been looking everywhere for that.
    Sep 2010
    The Hills.
    152.79 MB
    Hmm... Why on earth did Ritters put two sticks in mine???? It's nuts, and none of the instructions on the knobs are correct.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by johntins View Post
    Hi John, Probably done on price. The Proper CDL kits are quite expensive. Used ones are rare, and go quickly .
    I've seen some "T bar" Shifter like levers in the past. They look shocking. There was another mob selling and installing modified Wiper motor CDL shifters, they failed when mud and water killed them.
    Ashcroft do a CDL kit that looks factory.
    Cheers, Mario
    Aug 2015
    Moe
    Cheers, Mario
    So does Les Richmond. CDL kit It's still pretty pricey though.
    Mark F...
    Vk3KW
    2002 D2 Td5 auto - current AKA The Citrus Money Pit
    2000 Disco 2 Td5 Manual - dead and gone
    197? Range Rover - gone
    1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
    Outback Campers Sturt
    http://jandmf.com
    Sep 2010
    The Hills.
    152.79 MB
    Cheers, Mario
    That probably explains it, but it looks ridiculous and is clumsy to use. Hmm. Just looked at the Les Richmond one. $950? Think I'll out up with it a bit longer....
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Ive got the Ritters one as well and its got two levers. I'm used to it now. The real one is much more expensive
    Sep 2009
    Central Vic
    Quote Originally Posted by timdo1 View Post
    the 3 amigo's only come on when you turn the ignition off & back on with CDL engaged.
    they will go away when you have the ignition off & dis-engage the CDL.
    I left mine this way, so when going up a Steep greasy hill you can can use the CDL with traction control.
    If i get stuck half way up a hill & need to reverse down, i dont want the ABS to work, its bloody dangerous,it may be good on a road going forward.
    but when a wheel starts to slide/skid going backwards in the bush the ABS releases the brake on that wheel,
    the very wheel/s stopping you sliding backwards out of control....not a good feeling.
    So if im stuck & need to go backwards in a dangerous place, i turn the ignition off then back on with CDL engaged, this disables the ABS & im in control, not the ABS..
    Some will not agree, but have found this from experience....
    89 RRC
    92 RRC Sherwood
    May 2016
    nowra
    Agree roverv8
