Yes 8mm hex key plug is thr level plug. Located drivers side of rear diff too. Transfer case has same size allen key but different looking plug/ drain. Use a high quality 75w90 full synthetic oil in diffs and ONLY the genuine landrover transfer case fluid. 1.2litres required.
Don't forget to service the autobox and convert to serviceable steel pan.
Don't use additives.
Jc
