Thread: Just one of those days I think
    Apr 2015
    Bondi Junction
    We are moving house next week, and my 110 is a bit of a mess so I got in to clean it out, and fix a few minor things while I was at it.
    Decided to check out the rust on the driver side firewall - quite bad on the inside where it bends to accomdate the pedal box. Got at it with a screwdriver to clean it up before spraying it with a rust converter and now I have a lovely hole directly to the engine bay
    Then I decided to check out the cause of my coolant leak on the passenger side, and also look at the oil leak from the oil return pipe off the turbo.
    Oil return pipe first and what happened? I tightened the bolt 2 clicks on the ratchet and off the head came!! Little to no effort required either so guessing the bolt was on the way out and not enough tension to keep the seal. So off the turbo will have to come to get the end of the bolt out.
    The only good news is the welch plug under the exhaust manifold is where the coolant leak is coming from - and I have an exhaust leak on cylinder number 5 so it will all have to come off anyway.
    I am thinking I should just stay away from the thing!
    Poor bugger
    2015 Defender 110
    Nov 2015
    Quote Originally Posted by JoeFriend View Post
    That'll learn you good and proper
    Sent from my A51f using AULRO mobile app
    "Lara" '02 Td5 Defender 110
    Love the life you lead, you only get one go round
    Apr 2015
    Bondi Junction
    Yes indeed, lesson learned. For now at least!
    Now just gotta check to see if the oil return pipe will leak horrendously while I wait to get it fixed.
    Sent from my SM-G900I using AULRO mobile app
    Apr 2015
    Bondi Junction
    My mechanic is booked out for a while, which means I have the lovely job of fixing the oil return myself to get up and running.
