 Originally Posted by
POD
				Have done one on a mate's 110. Didn't take pictures. Not a small task.
I've just ordered the kit for my own vehicle. Not looking forward to the job but I believe it is a good fix and a necessity.
We took the extension housing off the gearbox and used a puller to remove the female splined output shaft, it was tight as all getout the whole way off the splines, had no hope of getting it off with a couple of M8 nuts welded in where you can't get a welder in. Don't know if this was abnormally tight as it was the first one I've done. Mine will be the last.
