I've never measured the volume coming out of the bleed screw, though it is all dependant on how far the bleed is opened.
I have had fluid shoot over 1.5 meters into the air at a fair old pace from the bleed screw.
I would be hoping the pump is suspect, as a new steering box is a lot more expensive.
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
