Not recently, but I posted this a couple of years ago 300Tdi
So all up weight was 2220kgI got my defender weighed today at work as we had a set of truck scales available (same as those the mermaids use accurate to +/- 10kg)
I've got ARB Deluxe Bar with warn 8000lb high mount, driving lights, Kaymar rear wheel carrier, dual optimas, twine shower, toolbox, bluetongue compressor, plywood drawer in the rear and the R&R Beadbreaker was on board with 3/4 tank fuel.
Weights went as follows:-
Front right 570kg
Front left 590kg
Rear right 510kg
Rear left 550kg
The GVM of the vehicle is 3050 so I've got around 830kg to play with but the front axle loading is 1200kg. Our engineer said the rough rule of thumb would be that 30% of any extra load would be carried by the front axle with the remaining 70% on the rear.
Martyn
					 110 wagon wieght
 110 wagon wieght
