Results 1 to 10 of 18
Thread: Getting key section out of old fob
    I have a new key fob but am having lots of trouble getting the key section out of the old fob.
    The online video makes it look easy , just and easy pull out job with a bit of a wiggle
    Not so easy in real life
    Any hints or suggestions please
    Feb 2009
    Newborough, VIC
    67.72 MB
    Put the blade in a vice, and pull.
    Unless yours has been glued in. Mine had, and I had to chisel it out after the plastic bit broke off the blade.
    2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Should just pull out, mine fell out a few times so I araldited it in so I wouldn't loose it.
    Maybe your has been glued in also?
    Thanks Guys
    Maybe it has been glued in
    harr2521 Guest
    Had to hacksaw mine out
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    In case you break the case ( pardon the pun) getting the old key out, i just bought a replacement case on ebay from this mob, $2.99 inc Delivery , I'm still waiting for it to arrive. You reuse the existing electronics inside from your old one.
    Replacement 2 Button Remote KEY FOB Shell Case FOR Land Rover Discovery 2 | eBay
    Jan 2013
    WA
    I recently bought one, they are ok just, the plastic is of poor quality and the buttons are a bit hard, not that flex felling you have with the original. had to alter the casing as it was touching the micro switch constantly. saying that it is good as a spare.
    Cheers tt
    D2 2004 TD5 Classic
    May 2003
    On The Road
    these are like genuine,,
    first one was so good I bought another!
    key cutting by Mr Minnet is touch and go though,,
    Brand NEW Remote KEY Shell FOB 2 Button Case FOR Land Rover Discovery 1999 2004 | eBay
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Hi Pedro didn't see that one, would have bought that one instead.
    Cheers, Mario
    May 2015
    Williamstown, Victoria
    It has Valeo stamped on the shaft, just like mine, or is mine a non original?
    Build date 11th Oct 2003
    LROCV #1410
