Results 1 to 6 of 6
Thread: D3 Telephone ECU
    D3 Telephone ECU
    Hi Guys, The telephone system in my 09 D3 has started to drop out when on a call. You can call back everything is ok for a while. Checked for faults and I am getting in the Telephone ECU a fault code U3003 Battery voltage. I was getting this fault before I changed my alternator and I thought it might go away with the new alternator installed pumping out more volts. Not sure whether it is a bad connection to the ECU or something else. Does any one know where this ECU would be located so I could have a look and see.
    sheerluck Guest
    From memory, it's behind the right hand (driver's side) trim panel in the boot.
    Hi Dave, pulled the jack out but the only wiring I can see is for speakers and entertainment system and tail lights. Do I need to pull anything apart to get in there
    Cheers Bryon
    Up the front end of that panel
    sheerluck Guest
    And you need to pull that whole trim off to get to it.
    Thanks guys found it unplugged and plugged all the connections a few times. Called up the car a few times hasnt thrown up a fault yet. Let it go for a while and see what happens
    Cheers.
