Results 1 to 8 of 8
Thread: What Compressor Do I Have
    Been getting some 'Normal Height Only Available' faults and have been following AMK Compressor and "Normal Height Only" fault, and fix! thread thinking it may be time to replace a few things etc.
    Is it possible to identify what kind of compressor I have without first pulling the thing out?
    Ride is a D4 SDV6 my11. Is there some place I can just plug in a vin number to find out?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Mandurah WA
    I have the same model and year vehicle as yours,it is fitted with the AMK compressor.
    Williams West Aust
    From the other thread it seems an air cleaner upgrade is required
    If you guys sort something Im very interested.
    Yet to peer into that dark area.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Aug 2015
    Coolamon, NSW
    Andrew
    When I permanently fix my compressor issue, I will take photos of how bad the bore is on my compressor which is obviously caused by grit, as there was not a mark on the aluminium pistons
    - Justin
    Selling soon - MY10 D4 3.0 TDV6 SE with E-Diff & LLAMS, 265/65R18 Maxxis Razr A/T
    Moved into MY12 L322 4.4 TDV8 Autobiography
    VK2HFJ
    Mar 2016
    Kenthurst, NSW
    Sorry to revive an old thread but I couldn't see an answer if it's possible to find out what compressor a vehicle has without removing it. After going through 25 pages of threads concerning suspension issues I'm none the wiser.
    Reason I ask is that I have the dreaded "only normal height available" message and want to find out what compressor I have on my 2014 model before get my hands dirty . I have a IID tool but don't see an option to identify the compressor.
    2014 XXV D4, Traxide, Front Runner rack, APT sliders and protection, Runva winch, ARB bull bar
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by XXVDisco View Post
    I took the plastic guard off (to put on a metal one) and I was able to see the branding on the compressor. I did not remove the compressor. HTH.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    If you have a 2014 vehicle it will be the AMK.
    Even if it has failed and switched out you will still have the AMK.
    Mar 2016
    Kenthurst, NSW
    Thumbs up
    Thanks guys for the quick responses
