Results 1 to 10 of 16
Thread: D4 Brake Controller
    Oct 2011
    Falcon, WA
    D4 Brake Controller
    Hi all, I recently purchased a new D4 TDV6 Graphite and would like to fit a brake controller to it.
    We have not yet purchased a caravan but have plans to.
    I know there are lots of threads in this forum on brake controllers but I ended up getting a bit lost and confused as they sometimes deviate a bit........
    Can anyone recommend a decent brake controller that is going to suit the majority of trailer brakes?
    Also, can you direct me or provide me options on best spots to mount the controller?
    I was looking at the Redarc towpro elite and then read that they would not be suitable for certain brakes?? I think it had something to do with the NSW regulations?? Not that I am in NSW.
    I quite liked the redarc as it was small and would have been easier to mount than some of the more bulky units.
    BTW, I plan on putting a traxide dual batt system in, so the reason I want to put a brake controller in prior to buying a caravan is so I don't have to pull the car to bits twice............
    Thanks in advance
    Darren
    Williams West Aust
    NSW have their own regs it seems.
    Most of have fitted the Redarc unit.
    Make sure it gets wired as posted in the D4 trailer brake fitting thread.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Oct 2011
    Falcon, WA
    Thanks Andy!
    Do you have a link for the trailer brake fitting thread?
    I know you need to run the wires down to the rear left tail light and tap in there.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    It is a 'sticky' at the top of the main forum section page here
    http://www.aulro.com/afvb/l319-discovery-3-4/
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Jan 2008
    Lysterfield, VIC
    Another vote for the tow pro elite. I put that in mine recently and put it next to the headlight switch. It seems to be a common place to put it.
    I would get a LR specialist to install unless you are very competent with that sort of stuff.
    Dave.
    Dave.
    Hi.
    96 Disco 1 V8.
    99 Disco 2 TD5.
    LROCV.
    May 2013
    I think that the Redarc Tow Pro is a great choice for the D4... mostly due to installation size... no black box in the driver's leg area. AL-KO do not recommend it for their iQ7 disc brake controller... though I use it on this system fine.
    In NSW there is an extra requirement that the charge condition of the trailer breakaway battery can be monitored from within the towing vehicle. The NSW Roads and Maritime Services (RMS) vehicle inspection bulletin VIB6 stipulates:
    • It will be satisfactory if any trailer-mounted battery is constantly charged by the towing vehicle and a warning device is fitted to warn the driver (from the normal driving position) if the trailer battery charge falls to such a level as to render the trailer brakes incapable of meeting the requirements.
    • Trailers required to be fitted with caravan breakaway systems are not registerable if there is no means for maintaining the breakaway energy source in a fully energised condition (for example, if a charging and warning circuit is not fitted).
    • An acceptable warning circuit must incorporate either a visual or an audible warning device.
    The iQ7 doesn't have a backup battery but uses an air compressor/reservoir.
    Mounting locations include:
    • headlight switch plate
    • cigarette/power socket
    • a couple of locations on the console
    Redarc Tow Pro...
    And Redarc support it very well so you won't have a problem.
    Dec 2014
    Another vote for the tow pro here
    Sep 2013
    Tow pro - there's a lot of brake options that are fine with it
    Oct 2011
    Falcon, WA
    Tow Pro it is!
    Thanks for all the feed back fella's!
