Results 1 to 10 of 11
Thread: Speedo and fuel guage have stopped working.
    Brisvegas, QLD
    My speedo and fuel guage have just stopped working. Have I blown a fuse?
    Sean
    Feb 2016
    Adelaide
    Isn't the speedo mechanical?
    JDNSW's Avatar
    Not from TD5 onward if I remember rightly.
    Brisvegas, QLD
    I guess the speedo is mechanical in that it has an arm that moves around a dial as opposed to a digital speed readout, if that's what you mean. Although the odometer part of the gauge is definitely digital.
    For 2 completely instruments to die at the same time seems odd, which is why I though it must be a fuse. I had a quick look at the manual and fuse 4 seemed the most likely culprit, but when I pulled it out it looked OK.
    JDNSW's Avatar
    As you say, for two instruments to fail at the same time suggests there is a common cause. If it is not a fuse, I would suspect an earthing issue in the instrument cluster.
    Nov 2015
    Tamworth
    solution is about 1/2 way through this video:
    From the wreckers to laps down the main in no time!
    Brisvegas, QLD
    Quote Originally Posted by Andy130 View Post
    Those fellas have way more mechanical know how than me!
    Anyway, I've now discovered, after copping a blast from a car behind me yesterday, that my indicators also don't work. Strangely, if I furn on my hazard lights they DO work. So what is the common link between fuel gauge, speedo and indicator wiring?
    Brisvegas, QLD
    Turns out fuse 8 was the culprit. According to the manual this fuse is associated with the hazards and rear wiper/washer, so why it would affect the speedo, fuel gauge and indicators is a bit of a mystery. Anyway, glad it was just a fuse and I didn't have to pull the dash apart looking for a wiring short...
    JDNSW's Avatar
    Quote Originally Posted by mojo View Post
    .... Anyway, glad it was just a fuse and I didn't have to pull the dash apart looking for a wiring short...
    ......but why did the fuse blow?
    in the wild New England, NSW
    The important part .......
    If it blows again, disconnect (isolate) the speedo transducer (at the TC transducer plug ) - if the replacement fuse then remains intact replace the transducer. The transducers can develop an intermittent short, replacements are readily available and are easily replaced being retained by a single bolt on the rear of the TC .
