Is yours cracked around circlip groove, it is getting harder to source parts for these transmissions and ZF have put up their prices on the remaining stock.
I may have a A clutch assembly floating around in garage
Hello,
I am enjoying living out of the city but find I need some parts for my Auto transmission. It is zf4 22HP The main being a front clutch drum
casting number on the rear outside is 1043-402-050 on parts manual it is 554, also the last black metal disc on the clutch pack there are two together at the rear. Not many Land Rover here. Have tried getting from the states but still waiting for a reply been a while though. can trade I have one very good and one a little worn Transfer boxs (disco) both with diff lock sitting on my shelf. So if you have a dead one in your shed, it would be great to make use of the parts very easy to remove.
Ian
disco seriesII mods so far:-bullbar,hyd winch,
detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
In the event of nuclear war,Disregard this message
Ian give me a ring mate ,,
I have one sitting here ,,
I can send it over to you ...
Hello, Thank you for your offer any parts are good digging more into it there are lots of different sizes to fit. If you can find it that would be good. This one has broken around the steel piece where the input shaft goes in and the o rings is right there so the box would never work. looks like it was dropped with the bell housing off.
Ian
