I've compared mine against the distance pegs on the side of the road and it was spot on with standard tyres and now about 5% low with larger tyres. My speed was high with standard tyres and now spot on with the larger tyres.
 Master
						Subscriber
						Master
						SubscriberI've just returned from a long trip and compared the trip meter/speedo on the car (MY16 D4) with a GPS running OziExplorer. Trip meter says 9198Km, GPS says 8696K. That's a difference of roughly 500kms! Which one is right? If it is the car that is wrong how can I change it? The only change I've made is using GOE wheels with 265/60 R18 but I believe the circumference if these is not much different to the stand 19" tyres.
Rod
D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
 Wizard
						Supporter
						Wizard
						SupporterI've compared mine against the distance pegs on the side of the road and it was spot on with standard tyres and now about 5% low with larger tyres. My speed was high with standard tyres and now spot on with the larger tyres.
Bob
 Master
						Subscriber
						Master
						SubscriberGPS derived speed is correct, virtually cannot have error if travelling at steady speed. It depends on the refresh rate when you are changing speed. GPS derived distances I believe will be correct as well.
Vehicle odometers (distance) are quite unreliable in my experience usually with a constant scale factor. Vehicle speedo's likewise. Most are configured to run at about 6% error, ie 100km indicated = 94km real. This error is not neccessarily proportional over the speed range though. Every time I have checked my GPS speedo against one of the overhead speed radars they are always showing the same as the radar. This has been with maybe 6 different GPS units and with many of the overhead radars.
So in short the GPS odometer will be nearly exactly correct, the vehicle odometer is another storey though.
Cheers, Simmo
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
Link to my D4 Build Thread
D3 2005 V8 Petrol
 Swaggie
						Swaggie
						Absolutely! If you check at what displayed speed the vehicle will drop out of off-road height you will probably find it's around 53 kph, being actual 50 kph but modified for display by 2 kph + 3.5% because it has calculated the proper speed using the correct distance.
My notebook's GPS displayed speed varies near trees, jumping up and down by several kph.
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberI've driven three Mazda Bravo/BT-50's over longish distances and all had a speedo inaccuracy of 8-10 %.
My current Bravo came with 185R14's and the speedo reads 109 Km/hr when the GPS tells me I'm doing 100 Km/Hr. 'Upgrading' the wheels and tyres to 205/75 15's has resulted in the speedo reading 100 Km/Hr when doing 99 Km/Hr which is good enough for me.The resultant change in gearing (manual transmission) makes the vehicle much more driver friendly as a day to day, non loaded, drive. The handling and comfort is also markedly improved.
My cynical view is that the manufacturers engineer this deliberately to give the impression that the vehicle(s) give much better fuel consumption than they really do.
Why do you think the hire car companys love BT-50's. I had a major blue with a hire car company in Mildura several years ago when I deducted 10% from the distance travelled.They pretended to be shocked and horrified but the bastards knew all along and caved when push came to shove. Not bad when they're creaming an extra 10% on the odometer reading.
Deano
I wonder what would happen with a warranty issue if it was a couple of hundred kms out of warranty ?
Martin
 Master
						Supporter
						Master
						Supporter2003 D2a Auto TD5 good Landy gone
2015 D4 probably the most amazing yet, why get a RR?
