My guess is that leaving the first oil change until 140k is where the problem lies. An oil and filter change may help however if there are excessive clearances in the clutch packs and wear on the tc lockup clutch then no amount of servicing the trans will help. If The difference between input shaft and output shaft speeds exceeds a predetermined amount then this will generate a fault warning this is usually caused by low line pressure or too much clearance (wear) between clutches and this is the first sign of requiring a rebuild.
Jc
