9th August 2016, 10:00 PM
Half luggage barrier/dog guard for Defender?
I'm searching for a half luggage barrier/dog guard for my Defender 110.
Inquiries have failed to find any Australian half barriers, only full barriers. I don't want a full barrier because I have rear drawers, plus I want to be able to fold down the seats and lay long items on the floor under the barrier.
I've searched overseas and its possible Rimmer may have one, so I've emailed them to check.
Travall don't appear to have a half barrier.
They must exist though, as I've seen them in magazines.
Any clues anyone?
Sent from my GT-P5210 using AULRO mobile app
10th August 2016, 02:55 PM
Hi DiscoMick,
I might be wrong but I thought I read somewhere that Autosafe cargo barriers in Boronia, Melbourne, will make a half cargo barrier if draws are fitted? Have you tried them? Contact for them is 03 9720 5533. I have a full barrier of theirs fitted to my 2013 Defender 110 and it is excellent. Worth a try if you haven't called them yet.
Regards,
4Wheeler
11th August 2016, 08:08 AM
Hi mate,
I can also recommend Autosafe. I built my own false floor in my 110 (to store the spare tyre in the cargo space). I just did a few measurements and emailed them together with some photos to Autosafe, and they built me a half barrier to suit.
It's very solid and well made.
http://www.aulro.com/afvb/attachment...-rear-view.jpg
11th August 2016, 11:39 AM
#4
Thanks, but had a reply saying they don't do half barriers for Defenders as there is not enough demand.
11th August 2016, 08:55 PM
#5
I have been debating whether to remove the barrier from my new TD5 fender. You have inspired me to look at modding it so I can fit drawers by cutting it in half.
12th August 2016, 08:35 AM
#6
folding barrier
i also made a false floor and needed a "dog" barrier as apposed to a cargo barrier (needs adr compliance for strength). i also wanted it to be easily removed or folded in case i wanted to carry a full load in the back. i made up the frame and attached it via steel tabs to the upper seat belt mounts for the rear seats. it allows me to fold the whole barrier up into the roof space out of the way. couple of simple pins on the false floor to hold it in place when the barrier is down . the whole system isnt designed to be a cargo protection thing. just to keep our working dogs from jumping in the front. i reckon any steel fabrication company could make you one if you drove in and explained what you needed.
cheers.
12th August 2016, 12:28 PM
#7
There is one English crowd reckons it has one for 209 pounds, but I'm not sure if that includes freight. The cost is now up there with a local Milford full height barrier. Maybe I should just buy one of them and cut the bottom off. Or, I could remove it when I want to carry long loads.
13th August 2016, 01:44 PM
#8
This is the setup I have done in the back of mine for dogs recently. Just need to get them off to the powdercoater before they start to rust! I think I've got enough weld mesh left over for another one if you wanted me to bend one up for you Mick? As long as I can assume the mount points would be the same between a 90 and a 110 (and you don't mind welds that look like pigeon ****).
There are a couple of local companies Puppy Bars and Surefind Kennels that do this sort of work. They are around the $1500 for a full cage setup which is why I went the DIY route, but for a simple half panel would probably be quite reasonable (and I assume would be ADR compliant etc...)
13th August 2016, 08:40 PM
#9
Thanks for the offer. They look like a good job. I think Travall has something similar.
I'm just waiting for a reply from England after the weekend. Appreciate your offer.
14th August 2016, 06:27 AM
#10
Hi DiscoMick,
yes - Travall have a selection of dog guard options for the Defender. I was looking into this earlier (however have not proceeded yet).
Have a look here https://www.travall.com.au/land-rover/dog-guard
cheer
