Thread: Classic Rangie rear bar onto a D1
    Jun 2008
    Are they the same configurations onto the chassis? Anyone know whether it will fit? Thanks in advance.
    2006 TDV6 Disco
    Aug 2010
    Sunbury, VIC
    Would have thought it would bolt straight on, an ARB bull bar from an RRC will bolt on the other end, I know that...
    How it would actually fit the rear, im not sure - they are designed for the lower tailgate to drop down into them, so it may look a bit funny with the Disco's rear door, but only guessing.
    May 2012
    Dalyellup
    Yes, same. Will bolt on, although it will look slightly wider than it looks on the RRC due to the Disco having the corners raised and the RRC is flat. The towbars are the same too.
    St Helena,Melbourne
    4.28 MB
    And longer as the body on an RRC is longer and sits over the chassis more in the rear, on a D1 it would make a wide step.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Eastern Suburbs, VIC
    Fits. Sticks out a bit though, as in backwards, I'll see if I can find pic.
    EDIT: http://www.aulro.com/afvb/1581462-post2.html
    1986 Range Rover Hiline
    2004 D2 TD5
