Originally Posted by
JamesH
Am I right in thinking I need to take action now and I can't ignore it until I'm going on an off road trip because one day it will drop to bump stops?
Tardiness in raising the reservoir pressure triggers 'normal height only' but the inability to achieve normal height will trigger a drop to the bump-stops. Hence don't let the situation deteriorate too far by waiting too long before replacing the compressor.
I only change heights if the current height is not appropriate but will do so every time and replace the compressor as needed. For me, the variable height is there to be used rather than just keep the vehicle level regardless of load, for which it's also used.
