Results 1 to 10 of 20
Thread: FLAT BATTERY in a week 2003 4.4L Vogue
    Shirley Guest
    Hi Fellas,
    The battery gremlin strikes again.. From the P38 with a BECM that had insomnia to an L322 with a similar issue!
    Is it possible that I am missing something simple?
    I thought it might just have been a old battery so I bought a new one. A monster 880 CCA Calcium Job that cost a fortune and made sure it was fully charged on the smart charger, did a battery test and got the same deal after a week in the shed. Flat as a F*rt in a week.
    Checked the charge voltage from the alternator at 14.1VDC, No errors on the dash readout, no errors codes in the computer so I'm not game to lock the thing...
    Has anyone and thoughts on this problem that would have been contagious from older P38 to the L322?
    Maybe I'm not holding my mouth right or something??
    Help if it is at all possible,
    Shirley - Wyee Central Coast NSW.
    Mar 2007
    Shirley
    Try checking these;
    Sat=Nav - CD continually trying to load
    Headlight Wipers - if not working, power is on continually
    Rear Cargo area Amp - moisture around connectors
    Final Stage Resistor - check fuses for power
    I hope this helps
    Laurie
    Aug 2010
    Sunbury, VIC
    I would never leave mine for more than a week not running or the battery would go flat. I'd either disconnect the battery or start the car and take it for a run as ours didn't do much for the last 12 months we owned it - and I killed a battery in at in that time. It's one of the flaws of its design IMO, but if you're aware of it, you can stay on top of it.
    A bit of a PITA if you're using it infrequently like we did, but I think they were made to be driven.
    Maybe you have a fault like previously described or maybe you will just need to drive it more.
    Brisbane, Queensland
    Mines a later L322, but I parked it for 3 weeks as we were away OS.
    Returned and it started like I drove it yesterday. Even air suspension was fully inflated.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jun 2008
    There has been some recalls on some LR products for the instrument binnacle causing battery drain. The computers don't always go completely to sleep, so maybe look at that.
    Shirley Guest
    Hi Laurie,
    I hear you mate, and it seems that someone else has been investigating that area before I bought it.
    Will section off all the modules in the back and see if anything is staying alive when the ignition is off...
    Many thanks,
    Shirley...
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    How are you getting on Shirlewy, I joined the dead battery brigade today.Bought a 880CCA Yuasa to replace the 800CCA existing battery, Soi $299 poorer
    Queensland
    Hi Shirley and your flat battery is commonplace in a TD6 L322.
    They have a fair bit of power being draw from the battery, long after the key is removed.
    I was averaging 6,000Kms a month in my TD6 L322, yet on the rare occasions that I left it unused for more than a week, I would be lucky to be able to start the motor.
    My TDV8 L322 could site unused for a much longer time and still start OK.
    If you can, try using a battery charger when ever your RR is not likely to be used for a few days.
    You don'y need a high current charger, anything from 2 amps on will do the job.
    Charging your battery regularly will not only keep your battery in a good sate of charged, but will greatly help to extend your battery's life span.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Drive safe , Is it also a common thing for a V8 as Shirley's is a V8 not TD6
    Queensland
    Hi Roverlord and yes, the early versions of the L322 are all renown for large consumption of battery power when the ignition is off.
    I can remember seeing battery chargers suffer under the Range Rovers on display at the different dealerships.
