Page 1 of 10 123 ... LastLast
Results 1 to 10 of 96
Thread: 1955 Series 1 86"
    Mar 2007
    Tarneit VIC
    1955 Series 1 86"
    Bougth this one 3 weeks ago with holden engine in it. Picture taken after the first bath
    Mar 2007
    Tarneit VIC
    Both wings off to fix some dint using hammer dolly. Found a big spider hiding behind RHS brake and relocated him to the backyard.
    RIVERLAND, SOUTH AUSTRALIA
    Quote Originally Posted by dearot View Post
    Looks good! Any rot? The red inside paint indicate fire brigade use maybe?
    Mar 2007
    Tarneit VIC
    Today manged to take the front grill off and radiator. The radiator looks like its been modfied to fit holden engine. The front cross member had been cut too for raditaor to sit on. Is this how usually they do it to fit holden engine into series 1?
    Originally where the radiator sit? On top of cross member? If it is on cross member it will be too high. Bonnet wont be closed properly.
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by digger View Post
    Only on front cross member and some part of the bulkhead. Chassis seems good only surface rust.
    The inner side of the bonnet is red. Could it be the original colour or its the top coat?
    Mar 2007
    Tarneit VIC
    Today manged to take the front grill off and radiator. The radiator looks like its been modfied to fit holden engine. The front cross member had been cut too for raditaor to sit on. Is this how usually they do it to fit holden engine into series 1? Originally where the radiator sit? On top of cross member? If it is on cross member it will be too high. Bonnet wont be closed properly.
    Found DR Johnston holden conversion and it hows they do it which is what they did on mine series 1.
    Is that mean it would be easier to retegister the car as it is the most common conversion method at that time?
    australia
    hi i am cutting up s1 chassi good cross member can post jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
    Narre Warren South
    Not sure whether a tester in VIC will allow a modified crossmember.
    When originally done it was probably on continuous registration so never went through a roadworthy.
    If you intend to put an original motor back in then it would be worthwhile getting a crossmember & putting it back to how it was originally.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by gromit View Post
    Not sure whether a tester in VIC will allow a modified crossmember. When originally done it was probably on continuous registration so never went through a roadworthy. If you intend to put an original motor back in then it would be worthwhile getting a crossmember & putting it back to how it was originally. Colin
    Not sure whether I will get an original motor or not. Its not that easy to get one here in vic.
    At the moment if it will be harder to get RWC with modified cross member is to put an original cross member and get a custom radiator to suit and still put a 202 for the time being until a good 2.0L replacement is available.
    Free Again Thanks Dan
    In my opinion any welding repairs to a chassis should be inspected by a engineer for Rego by the books.
    So even if you replace the xmember by rights it should be engineered
    But if it looks standard there should be no alarm bells
    Read between the lines
    But as others have stated if the car is or was registered with that conversion and engine some state`s will not require a engineers report
