Results 1 to 3 of 3
Thread: D2 Low mount winch on D2A ARB Bar
    Mar 2016
    Roselands
    Long time landy owner... first thread. Be kind peeps.
    Currently own a trouble free (kiss of death?) 1/2002 D2 TD5 which I fitted a D2A S2 ARB Bullbar (ARB code 3432120) some time back. I've finally decided to fit a winch however am uncertain as to which winch will fit now that there are a plethora of new winches on the market to chose from.... compared to the last time I did this 30 years ago. My intention is to fit a low mount winch, > 9000lb , at least 6hp, waterproof and using synthetic rope (even though I have already uprated the front springs/shocks). Has anyone already successfully fitted a winch with similar specs with minimal modification willing to recommend?. Thanks in advance!
    Last edited by Notamungo; 21st August 2016 at 03:45 PM. Reason: Error in description
    Dec 2009
    Baldivis WA
    I've fitted a Runva 11XP Premium to that bar with no issues. If the winch is using synthetic rope you'll need an offset hawse or the specific ARB hawse mount if you use a non-offset hawse.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Eastern Suburbs, VIC
    I recently put a runva 9500 on my d2a. Bolted straight up no probs to my ARB bar with an offset fairlead. Just had to rotate the gearbox so the freespool lever was in the right spot which takes all of 5 mins.
    1986 Range Rover Hiline
    2004 D2 TD5
