Results 1 to 10 of 22
Thread: Iridium Go
    in the wild New England, NSW
    Iridium Go
    My family now insist that I carry satcoms with me for emergencies when I venture into non-mobile coverage areas (they think I'm getting too old ).
    After researching - it seems to me that the Iridium satellite wi-fi "Go" system (used with a smart phone) is the most straightforward, convenient and lowest priced practical option.
    https://www.iridium.com/products/details/iridiumgo
    Has anyone had any experience with the Iridium Go system - good or not so good ?
    So, as I'm about to lash out $2k (device+prepaid), your comments/answers would be appreciated - thanks
    Jun 2016
    Tamworth
    I'm not real good with too much of this modern computer stuff, but I have heard of an app (a term I hate) that you put on your phone. If your in or out of a service area and you are lost or in trouble you activate this app and it locates you via satellite and sends your position to the authorities. I heard that the first week it was released it saved the life of two bush walkers. However, as I say, I don't know what it is called or how to get it, so I will leave you with this useless piece of info. Sorry, Grant
    Those of us that are inclined to worry, now have the widest selection in history.
    Mark Twain
    1989 Perentie FFR
    1956 Series 1
    The new Spot would work for you.. and a lot cheaper..
    Sat phones are often woftam...
    The Spot (high end one) can send SMS and signal for help.
    I refused to carry my Work SatPhone as it was useless.
    Aug 2012
    I went through all the options available about 12 months ago before the trip to Lorella Springs. In the end I went for a Iridium 9575 from Telstra. I haven't kept up to date with technology since, so how useful this info will be is debatable.
    The main factor I would say is whatever you go with, use the Iridium network of satellites. I have never not had reception (despite everyone telling me it would be useless up in the Gulf), and have successfully made phone calls from the bottom of valleys in the High country. I charge it, turn it on and test it before I go out each trip, it otherwise sits turned off in it's case for 99% of the time.
    It's probably not the cheapest option at $105 a month (for the first 2 years until I pay off the handset at least), but I know it will work, and if I ever use it in anger it instantly pays for itself. By the same logic, for the peace of mind it gives me, $2k over 2 years is nothing.
    Happy researching!
    Avoca Beach
    There is a misconception around that if you are out of range of your provider that if you ring 000 it goes to a satellite.
    AFAIK what happens is that it will roam and find any provider and link via them.
    I have been told the satellite story before and checked it out then.
    If it is so easy , why does a sat phone cost $1000? and why are SPOT and satsleeves sold.
    Regards Philip A
    Mar 2009
    Port Stephens N.S.W
    I last month, did a new sat phone, for $850 on a $15/month no contract/term with calls at 0.99c/min and SMS at 0.50c per message ... Post paid, so I never run out of credit, and the calls are cheap enough that I'm not worried about using it ... That's roughly $1k for the first year plus calls ... $180/yr for the service plus calls after that ... $2k takes you along way on this deal.
    No, it doesn't do data, but really, at $5/MB ... $5000/GB why do you want data ?
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Thanks Kev , who is that satphone with please?
    Aug 2012
    Correct. I've had quite a few arguments with people over this one. Here's the official quote from the government website
    "112 is a secondary emergency number that can be dialled from mobile phones in Australia. Special capabilities, including roaming, once only existed when dialling 112, however mobile phones manufactured since January 2002 also provide these capabilities when dialling Triple Zero (000) to access the Emergency Call Service.
    There is a misconception that 112 calls will be carried by satellite if there is no mobile coverage. Satellite phones use a different technology and your mobile phone cannot access a satellite network.
    Important ? if there is no mobile coverage on any network, you will not be able to reach the Emergency Call Service via a mobile phone, regardless of which number you dialled."
    Triple Zero (000)
    Jun 2016
    Tamworth
    Quote Originally Posted by MVFrancis View Post
    Triple Zero (000)
    I agree, what I meant was that this "app" accesses the satellite the same way your "map feature" does. The phone becomes a gps that gives your location. Anyway, I have no idea what it is, how or if it works. But I have been able to see my position on the map with my phone when I've had no mobile signal!
    Mark Twain
    1989 Perentie FFR
    1956 Series 1
    Aug 2012
    My understanding of that is that yes, your phone will be able to display it's location on a map, as the map has been saved to your device whilst in range of service. I used my normal phone in exactly this method whilst on Lorella Springs and also down the Oodnadatta track. Worked very well.
    Where it becomes a problem is that whilst the phone knows exactly where it is, it has no method to transfer this information to any other party- hence the need for sat sleeves etc.
    I am intrigued nonetheless and will try and find anything further
    Anyway sorry for the hijack
