Results 1 to 10 of 14
Thread: disco trailer ideas....
    Upwey, VIC
    Started a new thread....
    Originally posted by matbor+--><div class='quotetop'>QUOTE(matbor)</div><div class='quotemain'><!--QuoteBegin-hook
    Which one was build first, the G4 as above
    or this one seen in Cairns
    Love it... here is a bigger version of the pic...
    http://www.aulro.com/albums/album64/S3700323.jpg
    http://www.aulro.com/albums/album64/S3700320.jpg
    Looks like they have kept the LR diff and running gear, cut it in half, reinforced it and sealed it and just welded a draw bar on it. Also looks like they have also just run overrun brakes to the original LR ones... pretty cool. Also pretty cool because u could leave the petrol/diesel tank in place and u don't need to carry jerry cans !!!
    How heavy do u think it would be :?:
    Now who has a wrecked disco that I can have [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    Matt.[/b][/quote]
    Was thinking about the weight, and it would be quite heavy, axel, that ladder frame chassis, door's etc... would weight at least 500-900 kg's in the above setup
    But in a effect to make it lighter, you would do the following :
    1. replace all glass with either tinted Perspex or aluminium painted black
    2. replace the axle and suspension with different setup (but then again, I would prefer to keep the original setup)
    3. remove all of the interior, I mean all of it !!
    4.
    Got bored today and was thinking how I would set mine up,
    1. Full kitchen at the rear door, including the kitchen sink [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] all ready to cook, so all you do is open the door and turn the GAS on and start cooking.
    2. Rod holders inside the roof line and a oztent, and anything else that is long.
    3. keep the petrol tank and filler, and setup some form of transfer pump
    4. water tanks in the rear foot wells and twin Engel fridges on rails above this and clothing storage above that again or you could just have clothing on one side and one Engel on the other. you would also have one of the sides as your shower area, so that you have a shower screen hanging off the door.
    5. overrun brakes using the disco original ones
    6. have the oztent awning running when the oztent is setup at the back door from the top of the back door so that u can enclose the rear off it is wet !! or u could setup some awning that rolls out when you open the door, now that would be clever !!
    7. toolbox on the draw bar, which would have recovery gear and batteries stored there, also u could put the GAS bottles there too, similar to a caravan.
    8. above toolbox, either a mountain bike rack or another spare wheel.
    9.
    As you can see there is sooooo many possibilities here !!!
    Would be a good project if you wanted something unique !!!
    Only wonder how it would go off-road, don't think it could handle the real rough stuff, but that doesn't matter.
    Matt.
    Bracken Ridge, Qld
    re the first point 2: In Qld at least and I'll bet other states aer similar, you can;t legally have a trailer using the diff you need to make up a new / one piece axle from hub to hub.
    re the second points:
    3- if you mean a transfer pump to transfer fuel from the trailer to the vehicle (as it was driving) that would be very dangerous and probably illegal.
    It seems to me that it would be a VERY heavy outfit, not suited particularly to off-road travel. It would probably end up costing youas much as a decent camper trailer.
    But I'll grant you - it would LOOK cool :!:
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Jul 2003
    For a sleep-in version why not start at the A Pillar / firewall?
    Mahn England
    Ex 300Tdi Disco:
    I'm not doubting you Vlad but I wonder why. The rear axle of a RR/Disco would be quite strong. I saw an article in RR Club mag of a trailer where the owner used a RR rear end and used it to carry a spare diff as well.
    Ron
    Bracken Ridge, Qld
    Because its bureaucracy - rules made by those who do not understand much, that's why.
    The reference and links to forms etc (that show requirments for a trailer that can be registered) are here:
    http://www.transport.qld.gov.au/qt/LTASinf...estion2#trailer
    Thanks for not doubting me Ron [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] .... that makes ONE of you [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    gone
    1996 Discovery 1
    current
    That's OK. I'll doubt you tomorrow.
    Ron
    Upwey, VIC
    Originally posted by VladTepes+--><div class='quotetop'>QUOTE(VladTepes)</div><div class='quotemain'>
    3- if you mean a transfer pump to transfer fuel from the trailer to the vehicle (as it was driving) that would be very dangerous and probably illegal.[/b]
    God no.... more just a simple syphon...
    <!--QuoteBegin-VladTepes
    [/quote]
    Very true...
    SYDNEY -in the shire.....
    <span style="color:blue">for fuel transfer a simple electric fuel pump....
    preferably one with a high flow rate....
    also the tank will already come with a fuel pump.....
    all you then need is a bit of fuel hose to run to your tank then switch the pump on.....
    simple......</span>
    8) vlad, i don't believe a diff is illegal on a trailer - couldn't find reference to it in the form you put up.
    years ago we had a 7 x 5 with an old ford diff it towed really well, a bit heavy to push around [therefore heavy to tow] but it rode well.
    Safe Travels
    harry
    Upwey, VIC
    Here you go, "National Code of Practice for BUILDING SMALL TRAILERS" don't know how current it is, someone sent it to me a couple of years back...
    http://disco.bordignons.net/misc/Building Trailers.pdf
    Matt.
