Using a high flow just takes a bit of thought and practice. Best to hold the nozzle firmly against the open neck of the filler and slowly bring the pressure up and ease off if and when it starts spitting back from the air release vents that surround the filler neck. Always use gloves as diesel is carcinogenic and they keep the small off your hands.
Apart from that just take it easy when using them. I can get the tank full to the brim with no problems just by doing the above. But after several hundred refuels over the last four months on the road I also have had a large amount of practice.
I don't like them simply because they are quite heavy but you learn to live with them
Rob
				Rob
MY15 TDV6. Compomotives with KO2's, Traxide 160-DBMS, Llams, OE bar, custom rear storage slide, Rhino roof storage system, LSM TPMS, ICOM 440N, rear ladder and GOE compressor guard
