Results 1 to 10 of 12
Thread: Off Road wheels for D4 HSE
    D4HSEBP Guest
    Hi All,
    Just bought a D4 HSE with a Black Pack, looking for some off road wheels that will fit over the brakes any suggestions?
    nichwirth Guest
    Hey mate,
    You will need the compomotive pd1881s from GOE.
    There are also a couple of other options. Kmc have wheels that fit, they are not load rated.
    You can run the 2.7 d4 front caliper and disks. This will need an engineering cert. Good luck getting that.
    You can shave the caliper, gets done plenty but won't be legal, again you can run spacers same deal.
    Mud tech 4x4 have rims but they are just as dear as the GOE rims.
    Sent from my HTC_0PJA10 using AULRO mobile app
    Brisbane, Queensland
    You can fit 20" rims. There are better off road tyres in 20" than in 19". There are a couple of off road tyre options that are OK in 19" apparently. However, unless you're going into a pretty harsh conditions I would wear out the OEM tyres.
    I should mention I chose to go with GOEs for peace of mind on rocky roads and have a tyre size that is common for Prados and others so easier to get if I need a replacement. I also carry a 2nd spare if I have the trailer.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Nov 2013
    Forestdale
    If you have the 20" Black pac, I recommend keeping them and upgrading the rubber to Nitto Grapplers 265/50/20.
    Thats what I did and approx 40K later and trips to Cape York, Red Centre, Fraser Is (multiple) and numerous 4wd parks etc, I have had to replace 2 tyres (approx $500). You can do the maths for the GOE option, but if you have endless budget than GOE is better, else the NITTO all terrains are great on road and off road. Have had some minor scratches to rims which I plan to paint when they get really bad. Still way ahead of my budget, so i can spend on other extras (LLAMS, extra tank etc....).
    Good luck with whatever you choose. You have a great car for any offroad and its really comfortable in any conditions.
    Jun 2016
    Blue Mountains, NSW
    Quote Originally Posted by First LR View Post
    Sorry for a slight diversion.
    Andrew, did you notice any increase in road noise when you changed to the Nitto's from the OEM/previous tyres?
    Nov 2013
    Forestdale
    No noticable sound difference from the Nittos.
    The most noticable sound difference was adding the Snorkel and listening to the car's heavy breathing ! Only an issue if the windows are open.
    Peejaytoo Guest
    Smile
    So Fossicker on your trips to Fraser:
    Were you towing a van?
    How much if any did you have to drop the tyre pressures?
    Did you get into deep sand or go to Inskip?
    would be interested to know as we are heading to Fraser next month and I'm concerned about running the standard 19" rims/standard tyres combination.
    Bunbury, WA
    Quote Originally Posted by Peejaytoo View Post
    I wouldn't over think the 19" wheels issue too much. I have been on plenty of soft WA beaches with my 19" wheels with no issues. Deflate your tyres and drive sympathetically. Some rods or LLAMS to get the underside up off the sand is well worth it also.
    Jan 2015
    Quote Originally Posted by cjc_td5 View Post
    Completely agree with Chris on this. I have Compomotive 18s now but spent nearly 2 weeks on Fraser with 19s and GOE rods. They were fine on the sand. I did end up pinching one tyre and getting a little bubble in the sidewall but that was on a tree root on an inland track and completely my fault for not bumping up the pressures a bit once I was off the sand.
    On softer sand I went down as far as about 16psi but most of the time I ran about 18-20.
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Jul 2016
    Hey mate,
    I've taken my 19"s everywhere. 18psi seems to be the magic number in really soft stuff but low 20s is good for general driving and gives a bit. Ire protection for hidden hard stuff.
