Results 1 to 8 of 8
Thread: alternaor output
    Perth WA
    alternaor output
    Hi All
    My 92 Rangie 3.9 v8 classic battery light comes on fairly brightly at night with lights on
    while idling at the traffic lights (around 800 -900 RPMS)
    Its fainter cruising at 2000 rpms.
    The battery started to needing recharging (I don't know how old it is)though I did purchase car in May this year so with SWMBO approval I had RAC in Perth replace the battery tonight.
    While he was here and before he replaced battery has him check output of alternqator.
    At idle around 1000 RPMS reading on his mulitmeter alternator was charging 14.4 volts and with lights on it it was 13.98 volts.
    Is this OK ....should I worry that the alternator light still comes on and is fairly noticable at night.
    I don't own a mulitmeter .....should I get them out again to recheck output.
    Appreciate any feedback
    Baggy
    Oct 2011
    Fremantle WA
    G'day. I think the alternator on the 93 wreck was overhauled not long before, if those figures turn out to be a bit low - but seem ok to me. Cheers
    Aug 2010
    Sunbury, VIC
    Voltage looks fine but there could be something wrong. First up, go buy yourself a multi meter - something to check your battery with won't set you back more than $10. This way, you can check the battery first thing in the morning to see what it is charged to. The alternator may just need new brushes or regulator.
    Sep 2009
    Check your earth lead is making good contact with both body, engine and chassis. Clean if necessary.
    When using the multimeter test at the battery not the alternator terminal with the engine warmed up and the lights on. Should be 14 -14.5
    Keep it on volts and with the engine running test between the pos terminal of the battery and the alternator output terminal (don't short anything to earth) there should be less than 0.5 volt. If more you have bad wire or connection.
    Do the same test between the body of the alternator and the neg battery terminal. Again less than 0.5 volt or you have a bad earth somewhere.
    Good luck Paul
    Oct 2011
    Sunshine Coast
    I second that about buying a multimeter. One of most useful bits of kit particularly when dealing with older LRs You can check continuity/resistance/voltages etc.
    So you have some idea of what might be wrong before going done path of spending $$$ if you haven't used them before, Youtube is your friend on this. Lots of DIY and how to use videos.
    Gosnells
    Stop procrastinating. ! - That's MY particular skill....
    A good multimeter.... or a few cheapies that you can afford to lose/replace/lose/replace again... is the Very First gadget you NEED in your Land Rover.
    YouTube, or any of us locals will teach you how to use it...if you have difficulty working it out. Rocket-Science it ain't.
    When you get around to it, start here... Top quality, and most important of all, has DC (Direct current) 'AMPS', the species of electrical current that lives in cars, - outside of the Alternator.
    Kyoritsu 2000 Digital Multimeter AC DC Clamp Tester 3400 Counts With Bargraph | eBay
    But this one will get you started, it DOES have 'Dc-Amp', the funny symbol of an 'A' followed by two parallel lines, one solid the other dotted.
    You NEED to be able to measure 'DC - Amps' so watch out for expensive & budget ones that do not have that facility !!!
    UNI T UT203 Digital Clamp Multimeter AC DC Resistance Frequency Tester 400ABI152 | eBay
    I paid over $70 for mine, (different brand, ) but it's got a little LED light inside the clamps so you can see what you're doing at midnight.... at the bottom of a coal mine...and you don't have ANY other light-source. Incredibly useful and worth $20 more....
    J
    The Lady Sarah, '95 Vogue SE with working Air Suspension...and electrics...
    Perth WA
    Alternator output
    Thanks Everyone for your advice.
    Thanks superquag for the links and the cheaper unit is more in my price bracket.
    I'll order one and wait for it to arrive to track down the problem.
    My call on your expertise as my electrical skills are limited
    In the meantime I can clean all the earth contacts as suggested by Bundy.
    I'll post results.
    Baggy
    Gosnells
    . . . Anytime that I'm not working, 'On the buses, - 'ee by goom'
