mate , welcome to the site.....but really did you read anything sat all before you posted?
there is a section here for every vehicle ever made by Land Rover and there are sticky threads for almost every maintenance procedure.
take a good look at the site and good luck.
btw the reason for my comment, you will get no help posting in the rules and guidelines section.
, my question is regarding the installation of EAS compressor washers on the P38 compressor mountings, these are the cup shaped units, 2 per stud. STC3068. RAVE helpfully suggest to replace as you removed them, but with a P38 on the 4th owner, these are pretty much jumbled up. it seems they are (bottom) curve up and (top) curve up, but cant seem to reduce vibration, all the photos i have seen have them every which way.. Replace rubbers, nuts and washers with new. Thanks
Regards.
it has been very helpful already.
, but 1 drive was enough. i did some research on the model prior to locating this one.
