Results 1 to 3 of 3
Thread: Replacing mid/high line mid-range door speaker
    Feb 2011
    Hobart, Tasmania, Australia
    Anyone replaced the mid range front door speaker on their mid or high line vehicle?
    My passenger side has been sounding horrible lately, so I pulled mine out of the door this morning. The assembly can be dismantled:
    It's just a matter of pushing on the tabs in these holes with a flat head screw driver:
    Found the reason for the poor sound quality:
    A single genuine Land Rover replacement is nearly $140.00 - XQM000510PUY | DOOR SPEAKER FRONT MID-HI RANGE DIS2 | Land Rover | Discovery 2 - 1999 to 2004 | Britcar (UK) Ltd
    So instead I'm looking at generic speakers to replace it with. The speaker measures approximately 64mm and to mount it in the factory grill/tube it's approximately 66mm. But as you can see, unlike most speakers it's frame is round without the mounting holes - perhaps a dremel can carefully cut these off? Otherwise discard the factory grill and mount straight on the door trim.
    Otherwise maybe I just put a set of 3" or 4" coaxles in there instead - the tweeter might not get much work as the amplifier seems to have the bandpass built into it.
    According to Rave, the factory specs are 4 ohms and 30 watts.
    May 2015
    Williamstown, Victoria
    Cone Repair
    You could repair it.
    Repairing Damaged Speakers / Drivers Article By Jeff Poth
    It might be cheaper to buy a pair of replacement speakers.
    Bo
    Build date 11th Oct 2003
    LROCV #1410
    Feb 2014
    Diamond Creek Victoria
    Check eBay dude. You can find better speakers for cheaper. And just swap the speaker itself to keep factory look if that's what you're after
