Results 1 to 8 of 8
Thread: Series 1 1958 sidescreens
    Dec 2015
    perth
    I am trying to find out which parts to finish off the side screens:
    which sort of rivets are used to attach the aluminium panel to the window frame ? is it these? (see photo) - I have looked through the workshop manual and parts catalogue and there does't seem to be anywhere that describes which sort of rivets are used where?
    What parts are needed to fit the fixed and sliding windows? There seems to be some aluminium frames of various profile and a channel for the glass to slide in? Doe anyone have some photos that show this please?
    I have one old fixed and one sliding window - I assume it is easiest to use these as a pattern and get new ones cut?
    Thanks for your advice -
    Queensland
    Join this mob.
    You will find out everything here.
    Land Rover Series One Club - Index
    Keith
    Cessnock NSW
    The rivets are what's known as 'mushroom head' I will look later and see if I have any in the shed, cheers Dennis
    Dec 2015
    perth
    Quote Originally Posted by Dinty View Post
    Thanks Dennis
    Cessnock NSW
    A day late (sorry mate) but here are the Mush head rivets that i used on my Series 1 door tops
    I bought them from an ebay seller in the UK, I have 61 left over, cheers mate Dennis
    Dec 2015
    perth
    Dennis, Thanks - just did a count - 26 per door (that's a lot for a small non structural panel!) I'm new to riveting (and Series 1's for that matter!)- have been looking at the domed rivets and tools for those - how do you set these? I'm guessing I'll need more than 61 to allow for practice/errors but would buy them off you if you want to part with them?
    Mike
    Cessnock NSW
    Mike, I knocked up these 2 tools today, just using what surplus hex steel I had
    one is the punch the other supports the head, this one supports the head of the rivet, secured in a vice
    the longer one is the punch, it is used to peen over the shaft of the rivet
    I used 1 (one) of the rivets so now there are 60, but I do have a few shorter ones spare, as you can see the home made tool works well, the head of the rivet
    and the underside showing the shaft peened over
    I hope that's some help to you, cheers Dennis
    Dec 2015
    perth
    Dennis, Thanks for the detailed post - this is just what I need! - have sent you an email.
    Mike
