Thread: Temporary Fuel Tank
    Jan 2013
    Molesworth,Tasmania
    Temporary Fuel Tank
    When I eventually fire up the series 2 - pending a proper clean, I thought I'd bypass the fuel tank as it looks a bit murky. Is it enough just to stick the fuel lift pipe in a bottle or do I have to be a bit more creative? Surprisingly , I cant find an awful lot of anything about it on You Tube and not much in detail on here either.
    cheers,
    D
    1957 88 Petrol (Chumlee)
    1960 88 Petrol (Darwin)
    1975 88 Diesel (Mutley)
    Aug 2012
    Adelaide
    Quote Originally Posted by Dark61 View Post
    cheers,
    D
    I dont see why that wouldn't work.... I'd do it.... but "suck it and see engineering" is how I roll!
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    That will work, but please be careful not to have any spilled petrol about, and ensure that there is no possibility of the bottle falling over or sparks nearby. (I assume a petrol engine - if diesel, the fire risk is minimal, but you have a fuel return line to deal with.
    yep, I reccomend a 2 or 3 liter coke bottle, drill a small hole in the cap just undersize of the pickup, poke that through the cap so it hits the bottom of the bottle. fill the bottle mostly full screw it back onto the cap and then start it. if you need to you can lift it higher than the pump and give it a gentle squeeze to aid priming.
    Jan 2013
    Molesworth,Tasmania
    all good - and thanks for the heads up re safety etc. Yes its petrol so will be careful. I have a new smallish plastic petrol can which is quite robust and will do for the job. I was thinking you might have to provide some kind of breather? but I guess its not as technical as I thought.
    Thanks for the help.
    cheers,
    D
    Crafers West South Australia
    You will need a breather if you're running the engine for more than a few minutes. I've seen a metal 4 litre petrol tin totally crushed by air pressure when attached to a fuel pump without a breather. The most important thing is to have your petrol container opening at least 2 metres away from any ignition source by using a long piece of fuel hose. Wedge the fuel container so it doesn't fall over and loosely stuff a plastic bag around the fuel hose into the container. If you could get a spare pourer top for the fuel container you could modify it to have a pickup tube and breather tube sealed into it.
    Narre Warren South
    Currently using a 4litre turps bottle while a tank is out of one of mine.
    It has a handle so I'm using a piece of wire to hang it under the seat.
    Be careful with the fuel pipe selection because some is only OK for fuel internally, when you stick it into a bottle of fuel it de-laminates.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
