Thread: Double Cardan Joint Ball Removal
    Northern Tasmania
    I've just rebuilt the front prop shaft on my 2004 TD5 Auto at 190000km
    The suspension is in standard configuration. On a trailing throttle at about 60 kph I could just hear a slight chirping sound, while I couldn't feel any movement one of the UJ's was hot to touch after a short run. On stripping it down one cup was completely dry.
    The universals came out without too much trouble, but I was having trouble with the ball joint as most methods apply an uneven extraction force (I'd read all I could find in the various forums)
    After removing the small oil seal, all the rollers and the small cup at the bottom, I noticed a small lip at the bottom of the hole. I then machined the small device pictured with a main body diameter of 13mm, lip 15mm, length 20mm, and a 8mm threaded hole through the middle.
    The device was inserted into the ball, and the ball rotated 180 deg, a long threaded bolt then allowed the ball to be easily extracted.
    One point I didn't see mentioned anywhere is that when assembling the universal both legs need to be inserted into the cross before the cups are inserted.
    I used Hardy Spicer K5-A757 universal Joints and a SCV-82B ball, which I think were the best I could find.
    I also couldn't get my grease gun onto the supplied grease nipples as it hit the sides of the cups before it was fully locked in. I eventually found an extended 1/4 inch threaded grease nipple that I used for greasing before reinstall the original nipples.
    I considered getting a Tom Woods replacement drive shaft but there weren't any available in Australia and the US$399 plus US$230 freight put me off.
    http://www.aulro.com/afvb/attachment...1&d=1473074621
    Jul 2010
    Hunter Valley NSW
    Did something similar with a m8 coach bolt head wedged with small chisel
    May 2003
    On The Road
    straight to the pool room!
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    I just took mine around to a mates place he tapped it with a welding electrode and it came out. He did something I didn't see, but came out easy after that
    May 2003
    On The Road
    um, was the welding electrode connected to a switched on welder??
    South Yundreup,WA.
    Doing this atm. The ball came out easily, the race it was in was a fair bit harder and had to use a dremel tool. Hoping to finish on next break.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Melbourne, AU
    Quote Originally Posted by CraigE View Post
    I'm about to rebuild my prop shaft. Hardy Spicer have the centre ball kit but they noted that the SCV-082B is not an exact replacement and some machining is required. I haven't seen this mentioned in any threads. I presume others have been able to press the new one in ok?
    thanks
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
